1 - 2 of 2 Posts
Anyone know what ball joints the rough country Uca takes? Purchased in Dec 2016, they are the press in style with out zerks. I have seen where someone said a Chevy ball joint, and rough country gave me the part number K6327P, which appears to be the bushings. Any help would be appreciated. The pic below is the kit I'm referring to. Thanks!!!
545316
Not 100% sure, but I think you need the Moog K6540 part number front upper ball joints. These are an early 2000s GM upper ball joint replacement and come with zerks. Might be worth grabbing a pair from a local parts house and measuring/comparing before you install them, just to be sure, once you get the bad ball joints out. As long as they match the ones you take out, they will be fine.
1 - 2 of 2 Posts
