So I was towing a battery home and didn't have it strapped down like I should have. At some point the new battery fell over and leaked some acid out of one of the cell seals on the top that wasn't pushed in all the way. When I got home I hosed it off with water for about 20 minutes. When I got back from camping 2 days later I noticed that I had some bubbles in the liner, I hosed it down again and dumped a large box of backing soda all over the bed. A week later more bubbles appeared so I gave it the baking soda and water treatment again. I talked to some people who deal with acid and the like and did some online research and they suggested cutting open the bubbles so that I could flush them out.
But now my bed looks like ****. What is the best way to repair this? I think If I was to have the bed re-sprayed it would cost about $2100 or so, so that's probably not a very good option for an 11 year old truck with 96k on it. Is there some roll in liner that might look close to what I have? I don't want to invest a ton of time and money into this as I still have an axle leak I need to address as well.
Here's the pictures:
Initial Spill
IMG_20161007_144744 by glamisduner, on Flickr
The bubbles, cracking and discoloration after a week and the backing soda treatments:
IMG_20161015_124810 by glamisduner, on Flickr
3rd Baking Soda Treatment and reaction after a few hours:
IMG_20161015_154602 by glamisduner, on Flickr
Here's the bubbles I cut open to flush out the acid that might be underneath. I guess I will flush this then grind them down more with a wire wheel?
IMG_20161015_164912 by glamisduner, on Flickr
IMG_20161015_164937 by glamisduner, on Flickr
IMG_20161015_164958 by glamisduner, on Flickr
IMG_20161015_164933 by glamisduner, on Flickr
So My plan is to do a 4th baking soda flush, grind these down and open them up more, then patch it with something? But what can I use to patch this liner?
Theres several other areas that are mushy now (although not bubbled) not sure if I should try to cut and remove these too? Is there any hope or at this point am I just making it worse? This isn't the easiest stuff to cut out of the bed.
Initial Spill
