1 - 8 of 8 Posts
So yesterday I put new 02 sensors in my truck ran fine last night and earlier today now it is running rough not like it normally does it also has a weird kinda shake like to it when I press the accelerator any ideas as to what it might be
Codes?
Well, start going through and resolving those items. You have a misfire, O2 codes, and several other things. Off the cuff I'd say check to see if you have cracked exhaust manifolds and do a compression check. You may have a dead cylinder and need a motor. Hopefully not.
I would go back and check your work. Make sure the harness isn't dangling and melted against the exhaust. Connection could be bad well. Also if you went too cheap on 02s that could be an issue.
P0301
Mil on
Monitor
0 inc
7ready
Misfire
Fuel
Comp
Catlyst
Evap
02 snsr
02 htr
That is what the code reader told me
So the miss fire was a coil pack replaced all spark plugs and number 6 was full of oil so on Monday going to replace the cylinder 6 rings so hopefully that stops the oil leak replaced o2 sensors the coil pack for 6 and it ran fine no more misfire yesterday ran fine today started bogging down again no codes thow
No I paid food money for them they were like 88 dollars a peice
Oil on the plug might not be rings. Depending on where it is (on the plug tip, or all over the plug body, it could be a bad seal at the plug on the valve cover. Solution there is to replace the valve covers (can't get the seal separately).
As for rings, if you tear into that motor before you do compression and leakdown tests, you're crazy. Diagnose it first, then start replacing things. Throwing parts at it is an expensive hobby.
1 - 8 of 8 Posts
