Thanks Guys! I wasnt sure but i almost want to order that stuff because im sure i could use it on something lol
Be careful on what you are painting because some things require the use of the Rust-Oleum Self Etching Primer. I used the primer on my bumper and grill then sprayed it with the bedliner and it is holding up very well. Also sprayed my mirrors so I would suggest roughing the surface up, self-etching primer, then bedline it...
Alright would i get that at the same store most likely and does it come in a spray can im assuming?
yep, there usually sitting right next to each other.
