So I just installed my S&B and I am a little dissapointed what $230 will buy you. The S&B Tube and box is SUPER smooth on the inside, so good for air flow. The Filter is MASSIVE, and you have a clear top to check it easy, those are the pro's. Some Cons though: No drain in the box for water. Only a single big opening for airflow. No rubber gasket around where the intake tube/filter go through the box so enough rubbing might start to wear on it.
So I have a fix/update to stock box mod. Instead of just cutting out the snorkle and adding a K&N or Amsoil drop in, Cut that whole side out. It will be a closed box similar to the S&B intake. And if you can find some piping from autozone or lowes, rig it up for a smooth intake tube. Cost might be $100 for both drop in filter and parts and it will be much better then stock.
Hope this helps someone! :hi:
