1 - 12 of 12 Posts
I found a few threads on this through searching, but am a little confused on the answer to the problem.
I've got a Sirius satellite radio plugged up into the AUX input on my radio, and I have to turn the volume up to somewhere in the 20's to get it as loud as it usually is at 10 or 11 with regular radio or a CD.
What are the solutions for this?
Banned
Have you turned the volume up on your Sirius??
Yeah, you should have a master volume on the unit. Overall it still doesn't play as loud as a CD or regular radio. its because of how they broadcast it. After a while you won't notice it.
Banned
ScottK said:
Unfortunately I don't think it has a volume control. It is a XTR3CK for reference.
Look it over, and get back with me.
If it has volume control, turn it all the way up, and you should get normal sound.
Discussion Starter #7
I'm sorry for not being clear, but I am about 99% sure that it does not have volume control. The only reason I said "I don't think" is because I've only been using the radio for a few days. However, I have looked through the manual and all of the menu settings on the radio and seen no mention of "volume." (except a "mute" option)
I would stay away from running it through an FM channel. I originally had my installed that way and i picked up a ton of static especially in the city. My buddy had the same situation on his A3.
1 - 12 of 12 Posts
