Hey guys I have a set of saw 2.5 and 2.25 rears what psi should I fill the rears and can I mount them any direction. Shaft side up or down?
thats a valving issue. You shouldn't adjust PSI to help the ride. you should have them re valved. Ditch the sway bar, its free, and easy, and AMAZING with SAWS.My SAW shocks and coilovers are currently at about 200 psi. It's really stiff. They were previously at about 125 psi and I would really like to go back to that setting.
My shocks are shaft down, body up. No issues.
I loved my SAWS when i had them back in 2012. also ran them with PRG uppers.Thanks guys. For your fronts how do you like the ride I have the 2.5 ext for the upper control arms.
Honda250xtitan. I just got ahold of greg at prg I'm sending all my stuff to him to be fully rebuilt.
I fpr got to ask him I want to keep the same hight or even go just a tad higher than what I'm at now.
Have belstien 5100s on top setting with I'm pretty sure is the 1.5 inch prg block. I heard some people loose hight is that true and if so how do you correct it?
try to get a hold of him and tell him that he should be able to set them up to keep that height. IE set the preload or flip the hats and use them as a spacer with minimal preload. thats how i ran mine.I'm currently sitting at 40.25 just about all the way around
