1 - 10 of 10 Posts
Wondering if anyone with a 2020 Pro 4X with black seats having a problem with the black peeling or chipping off. My drivers side seat is cracking and peeling some. Seems a little early for that. I've only had it a year and really not in and out of it a lot.
Adam
Sent from my SM-G781U1 using Tapatalk
They make leather conditioner and have for decades.
Please share what you are using then, because it isn't working. That leather looks dry as the Sahara.
Looks like sun damage. Shouldn't happen on a 2020. My seats looks like new but I use Lexol. Unless you're 300lbs and drag yourself in and out or live in Phoenix it's not really explainable.
2017 Nissan Titan pro4x
Man I’ve used a few leather conditioners in my short time but I found leather honey and never looked back. It’s literally like honey and coats like no other. Hope the best man, it’s seems too early even without regular maintenance!
No real reason why the leather should peel. They usually coat it with urethane from factory I believe. Since it’s only on the piping there must have been a problem there. A re-skin may be in order. May be worth it to pick up a Nissan leather product if it’s under warranty. CYA.
I’ve used Leatherique on an older high quality motorcycle jacket. It may have helped nourish the leather but the jacket dye/coating started lifting in places.
I’ve also heard Armor All or any silicone based products are terrible. That they magnify UV and cook vinyl dashes, leather seats and tires. Is there silicone in Chemical Guys? I heard they used to be good but we’re bought out/sold and quality dropped.
edit: you said chemical bros, my error
Of the mass produced brands as far as product lines go Meguires and Adam’s are both respected across product lines.
If you’re not looking to warranty you can use shoe scuff dye (kiwi) to cover it. Maybe sanding too but I really never have done any sanding on leather.
Anyway hopefully restricted to the seam piping only.
Adam
Too early for sure. Treat it with Leather cleaner and leather oil.
1 - 10 of 10 Posts
