1 - 2 of 2 Posts
I put a 3in body lift under my 2004 titan after completion my service engine light and my slip light will not go off. also, when i try to accelerate my truck cuts out like it is going to die. although if you dont feed it too much power the truck runs fine. Please help! thanks.
Altitude sickness?
Seriously though. The slip lght probably has to do with a wheel sensor. Check your installation and make sure you didn't leave something disconnected. The slip light and the SEL/misfire are most likely two different things. Bring it to an auto parts store that will hook up a code reader. Many will do it for free.
1 - 2 of 2 Posts
