So I've only had my Titan since the end of September and only have 700 miles on it. about 150 miles ago I put a JBA catback on it and just yesterday a Service Engine soon light lit up. Checking the manual it says a solid light means an emision problem. The gas cap is on tight and I crawled under her today and checked the connections and everything is tight. So I'm wondering if the exhaust is causing it or something else? Do you think if I take it to the dealer they will give me crap and not even deal with it at all for having an aftermarket exhaust? Any opinions would be great...thanks in advance!
First try resetting the ECU. You can do it yourself, it is free, and it is worth the try. Use the search function and look for a thread with instructions. If it does not go away, then take it in.
Cool, I'll give that a try... thanks guys!
Super Moderator
Interesting, I installed a JBA on my 07 and never had an issue.
My SES light came on last week. There are instructions in the "How To" thread that tells you how to read the code and then there is a link to see what the code is. I had code P1000 and could not figure out what the problem was. I did some searching and it appears the system that checks for problems could not complete its check. I cleared the code and drove it around and checked for any codes and nothing.
________
VAPORIZER
