Procedure
ekool said:
I wonder if there is a way to check engine codes easily.. For example, my SRT-4 allows me to turn the key to the on/off position 3 times, and then the code number is displayed where the digital odometer is. That would be very handy, along with a factory code listing.
There is a way to get codes from the vehicle without tools!!
This is the procedure:
1. Confirm that accelerator pedal is fully released, turn ignition to the on position and wait 3 seconds.
2. Repeat folowing procedure quickly 5 times within 5 seconds.
a. Fully depress accelerator pedal.
b. Fully depress accelerator pedal.
3. wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the mil light starts blinking.
4. fully release accelerator pedal.
note: It is better to count the time accurately with a clock.
The ECM returns to normal conditions when ignition switch is turned off.
The number of blinks indicates the DTC code!!
:cheers:
