Severe electrical issues
834 1
I was driving down the road when my ABS, SLIP, and 4WD light came on, when this happened the speedometer and the RPM gauges read zero. I still was able to drive the truck even though when i would go form a stop sign it would shift really hard into each gear. I drove it home and then shut it off after doing so I tried to start it again and It won't start up again. This isn't the only electrical issue i've had in the past 2 weeks. It started with no tail lights, when I checked the fuses they were all ok. Then no right rear turn signal followed by no break lights a couple days later. the past couple days it was going through fuses like crazy. So I'm not sure what the problem is but I'm guessing it might be the BCM. I've already replaced the IPDM box and the ECM relay and I would greatly appreciate it if anyone can help. Thank you.
1 - 2 of 2 Posts
1 - 2 of 2 Posts
