1 - 13 of 13 Posts
Ok, I have my new shackles part# 55220-ZR00B and will be installing them sometime over the next few weeks. Because I live out in the middle of nowhere I'd like to have all four bolts and nuts on hand for when I do the install. I'm a little unclear as to the part numbers when I try and look them up at the various online parts places. Here is a picture of what I need (Outlined in Red) If any of you know the part numbers for these bolts and nuts I'd appreciate it. My truck info is in my signature.
Thanks!
Those arent the whole part numbers, and one of the nuts is described as a bolt, I looked at that already. Courtesy does not use the regular Nissan part numbers.
This doesn't answer your question, but I really doubt you will need new bolts or nuts. Mine broke loose without spraying them, even though they had 5 winters of road salt on them. I used a box end wrench and a ratchet for each bolt along with a hammer to break them loose.
Did your replacement shackles come with the bushings installed? They have separate part numbers for the bushings, but others said they came pre-installed.
Yes, the bushings are installed when you order the part number I listed above. I appreciate the help, but like I said, being 100+ miles from the closest dealer warrants having the bolts and nuts on hand...... Thanks!
Thanks for the reply. The bolts and nuts are pretty hefty, and I can't imagine how anyone could damage them, but I guess anything is possible..
55220-A60002 is the Courtesy Parts part number for shackle+bushing.
Discussion Starter · #10 ·
I appreciate the help guys, but I have looked at all those illustrations.
If you call a dealer and give them the below two numbers they will tell you that they are not valid part numbers.
Bolt: 55080-A60002 $6.96
Nut: 01225-A60021 $0.99
The Nissanpartszone site is confusing because it give two different descriptions and part numbers for the nut. I'm pretty sure the bolt is a 55080-7S210, but they also show a bolt number of 55080-7S210 which in the illustration points to a nut.....LOL. Anyway you can see where the confusion comes in.
As many of you that have replaced these shackles I just thought someone else may have purchased a nut and bolt or two and had the part number of what they were sold. No biggie, I'll figure it out.
Fontana Nissan is a site sponser, surprised no one recommended them.
Discussion Starter · #12 ·
I tried dealing with Scott, but he tried to sell me shackles and bushings, his quotes on parts were incorrect. I asked him a couple times if the bushings came installed but he never answered that question. Then I told him I wanted the bolts and nuts to do both sides so he quoted me on two bolts and two nuts.....LOL..... It takes four of each. At that point I kind of lost all confidence with them.
Discussion Starter · #13 · (Edited)
Ok, I finally got this all figured out,
Shackles w/ bushings installed 55220-ZR00B
The two bolts for each shackle are the same 55080-7S210
Two nuts are the same as well 08918-6441A
So for a complete change of both shackles order two shackles, 4 bolts, and 4 nuts if you need them.
On a side note I found an electronic parts catalog from a Russian site believe it or not, you can use Google to translate. I entered my VIN# and it worked....LOL. Anyway the breakdowns seem a little more clear at this site and they give good Nissan part numbers.
Google Translate
1 - 13 of 13 Posts
