this tick noise is killing me. it sounds like its coming from the bellhousing but followed it up and its coming from the drivers side of the engine
only but echos all around. figured probably the well known injector noise or maybe a valve lifter or spark arch. you can only hear it when the engine is at running temp. the warmer the eng gets, the louder the tick (almost a clunk) gets. you cant hear anything inside even under WOT (except for beautiful vk and banks of course lol).
i built a grounding kit and im going to install it tomorrow to see if it helps. im using 4AWG copper stranded wire and the activetuning directions. is there anything else i might be able to do, tricks or advise, to quiet the engine noise down? thanks in advance.
