Just back from the dealership for another visit about my shifter, and I'm baffled / annoyed enough to write it up (not the dealership, the glitch). I'll try to give the condensed version --
Symptoms: Several weeks ago my shifter started to intermittently malfunction (2004 SE column shift, BTW). When I would shift to Park the little 'box' on the display would disappear, and then the truck would not start. Push in the brake and shift back and forth, the box would reappear around P and the truck would start, or I could start in N. Seemed to be happening after warmup, or maybe just on hot days -- not predictably, though. Also seemed to be increasing in frequency, so I took it in to the shop.
Fixes ... make that: Attempted Fixes: To condense this, the first fix was to replace the valve body, which solved the shifter P-R-N-D glitch but then I noticed (the next day) that the thumb shifter wouldn't work. So back I go, they replace the replacement valve body, still no thumb shifter. The next visit gets a new thumb shifter switch then a unified meter (the whole instrument cluster). Tech is still not getting signal through the system, the thumb shifter doesn't work, and they are baffled. They called Nissan 'tech line' and got some things to try, so back I go today. Tech, me, and others getting frustrated and now he's trying to trace out wiring to see if there is a fault. I pointed out that the thumb shifter worked before the first fix, they changed one part, and it quit -- seemed unlikely that there would be a wiring problem that just coincidentally happened at the same time. So they found my original part (hadn't been shipped off yet, fortunately), plug it in and voila -- thumb shifter works! (the old valve body could be plugged in with the external connector without having to drop the trans pan). So he put my dash back together and I got back to work, and they are following up with Nissan to point out there is some problem with the replacement part no. for the valve body, or some electronics in it, or manufacturing/design defect, or ... ?
Outlook: I have the 100K-mile warranty (thankfully, since valve bodies cost $1100) so I will get this fixed ... eventually.
I didn't find anything when searching from anyone else who has experienced this -- anyone else had these symptoms?
To be continued ...
To be continued ...
