1 - 20 of 43 Posts
· Banned
Ok need some advise from some of the intake guru's...fitment is taken care of and will work great with the ram air mod...im not worried about the pcv hose that can be fixed easy..my only concern is maf placement....where should i put it? or should i try this at all? i also need to find someone local with uprev that can read my afr's...here are some pics..its a work in progress...some info on the set up...its a very large k&n filter into a 4 inch ls2 intake tube to a 3.5 silicon elbow...ideas????
def build some kind of box around it.
Reactions: WIKEDVK
MAF sensor will work best as close to the stock position as possible i think...looks good though man
Reactions: WIKEDVK
Mike, I'll second Christina's request and say put it back together! LOL
Looks like It'll get some nice cold air... you may also need to get the depth of the sensor close to the OEM specs in order to get proper readings. I know location does/will play a role but I'm not sure on it's extent. Good luck!
Reactions: WIKEDVK
I think there is too many curves =)...Plus with the 3.5" elbow, your only getting 3.5" of air, no need for the 4" piece IMO. I mean, the 4" to 3.5" COULD speed up the air, but it may turbulent air which would negate any gains. Plus with the OEM TB and manifold....well, you know. Just my advise though, put the MAF in there and get it data logged. No reason not to try it. Cipher will tell the tale
· Banned
oh no man noooo!!!! lol you should just do the ram air mox in a closed intake box like s and b or aem or volant, he!! even in a stock airbox, anything than what you are trying to do.... im not trying to be a prick but that will make your intake air temperature skyrocket!!!!!! rule of thumb, the hotter the intake air temperature the lower your ignition timing gets... the ecu does that to prevent detonation aka knock. HAPPY MODDING!!!!!
Reactions: WIKEDVK
· Banned
Discussion Starter · #10 ·
thanks for the input guys...well update it works!!! lol for now...no codes no check enigine light yet...it had a pretty rough idle at first but the longer its on the better it gets....i dont wanna push my luck with having someone log it with uprev...but i went for a quick drive and it pulls alot harder then the k&n did...im doing a couple ecu resets also....i know that heat is an issue but there is no metal tubing at all on here so it wont get so much heat soak...im also thinking about get some heat tape or insulation tape to wrap it in....here are more pics
· Banned
Discussion Starter · #11 ·
thanks bro its still a work in progress....i know it does pull hard then it did....but i need to find out what the IAT's are...also i wanna see how much cfm it pulling i have some ideas how to smooth the air out more..just need to get more silicon hose first
That looks pretty nice. I like that! Nice curves too. ;)
One thing I would do (and this is just my own idiosyncrocy) is to place Hose Clamps on, with teh Nut on bottom or back, so it is out of sight. It simply gives an even cleaner look to have just one layer of strap visable. Really, just a thing to do for "show". I love it when people take time to make their own stuff, and do such a nice job as this. Anyone can go buy an AEM.
What do you have palnned for the empty spot, where you Intake used to be?
· Banned
Discussion Starter · #18 ·
Looks more like a kit than homemade lol, if everything is safe run it
Thanks man!!! I'm trying to make it look as nice as i can...
· Banned
Discussion Starter · #19 ·
If the seat of pants feels better, then that's really all that matters. Protect that filter and get it some cold air and insulate everything (if your not going for looks) and let 'er rip
Well i went for another drive it pulls like crazy....the rpms jump like a mofo..BUT!!!! it deff needs to be tuned....im more into power then looks for the most part but i want it to look nice too...
· Banned
Discussion Starter · #20 ·
Thanks!!! i have been thinking about doing this for awhile....so i have been tinkering for a couple days with placement and where to locate the maf....lol and all this stuff i had around the garage....i havent spent a dime on it so far...but its really far from done just need to buy some stuff to make it look a little nicer...im calling it a THI INATKE "titan hardcore intake"
1 - 20 of 43 Posts
