Can't answer all your questions, but the Titan 4x4 has good ground clearance, around 11.5" I believe. 3-4 inches more than an F150.
..how bout the bullbar I see on many Titans?? will it protect the lower radiator?? and is the frame pre drilled for it?? how/where does it connect to the bumper?? is the Titan frame pre drilled for all the skid plates??HudsonValleyTitan said:Ground clearance on the Titan is just over 9". These skid plates are not really made for hardcore offroading. But they do protect from small rocks and debris being tossed up while offroading. I don't know who makes the transfer case but, as you can see for yourself, it seems to be sitting pretty high up in the frame. Oh and BTW, please don't ever compare the Titan to the majorly inferior Dodge Ram!...lol.
the bullbars do not protect anything really, except the bumper itself. The skidplate that is on the bullbars is extends no farther back beneath the truck than the bumper does.IGBT said:..how bout the bullbar I see on many Titans?? will it protect the lower radiator?? and is the frame pre drilled for it?? how/where does it connect to the bumper?? is the Titan frame pre drilled for all the skid plates??
54warrior said:Also, the title of your thread mentions something about the OEM shocks, but you didn't ask anything about them in the post? What kind of ? did you have regarding the OEM shocks? We'd be more than happy to answer.
Depends on the model. The 08 OFFROAD PROX comes with the Ranchos. Prior years can be had with Ranchos so long as you had the OR package.IGBT said:..Yes. I forgot. Are the OEM shocks in the 2008 4x4 heavy duty/ok for awhile? Or did they install cheapo's just to get the vehicle out the door??
