1 - 6 of 6 Posts
Hey everyone, I'm in need of help. I got an '04 Titan and a couple months ago the slip and abs light came on while driving. I got the truck scanned and it came up with 4 codes...
C1109 battery voltage abnormal
C1103 circut of right front wheel opened
U1000 ECM not transmitting or receiving
P1716 turbine revolution sensor.
I did buy a new hub and just hooked up the sensor to see if the light would go off, but that didnt work. I read that if in need of a new battery, it will throw the abs light. I did check the brake fluid and topped it off to see if that helped. But nothing. I'm hoping someone has had this issue before and knows what to do to fix it,
Thanks in advance
What was the solution?
I have the same problem , what fixed it ? And ever since those lights came on it won't go into 4high or 4low. Please help thanks
I have a 2007 Armada se 49k 4x4. Driving on the highway +65mph the Slip light and 4wd light flash on dash and there is no acceleration In both 2wd and auto 4wd. Any suggestions?
Thank you,
Reed
1 - 6 of 6 Posts
