1 - 6 of 6 Posts
2006 Titan - When starting the truck, the slip light stays on and the light with the diagram 4wd is missing. You can't get it out of 4wd, or put it in 4wd. Going down the road, the diagram light comes on and the slip light stays on, but you can change it in and out of 4wd. I have spent over a thousand dollars trying to get this fixed. The ABS module has been chg'd and reprogrammed. Sensors and wiring checked. No one seems to know what the issue is. Any ideas? This is the best truck ever, just needs this fixed. Love my old Titan!
Good luck. Everything that I know to do, you have already done. Mine had cracked wire at the ABS connector at the wheel. Fixed the wire and that solved similar issue for me. YOu said wiring has already been checked though.
Good Luck!
1 - 6 of 6 Posts
