What's the smallest adapter/spacer you can run without cutting the lugs?
Should have measured when I had the wheel off but I forgot. I'm thinking it's 1.25".
Thanks!
You can do 1" depending on the wheel you're using.
Thanks for the replies! I have a -44 offset but am just trying to get spacers for the front to compensate for the lift sucking in the track width. If you really look at the truck you can tell the front has a narrower stance in the front then the back
1" works on stock wheels. 1.25 on fuel wheels.
i ran 1" on my fuel wheels....it left some "marks" lololol
