1 - 11 of 11 Posts
SOLD
2005 Nissan Titan 4x4 LE Crew Cab (ONE OWNER)
81,002 miles
VIN 1N6AA07B75N506313
CLEAN TITLE
Asking $13,500 (see below and pictures you will see why)
Located in Williamston, MI 48895
Super clean and meticulously taken care of. You will not find a cleaner 14-year-old truck. Great sounding and unique. All maintenance records since purchase at 481 miles July 2005. ZERO accidents. This is my extra car. Just had a baby and now need to sacrifice my other baby.
54,000 miles (NOV 2012) Superior front axle 4.10 ring and pinon gears installed.
65,700 miles (APR 2016) Alignment check.
58,000 miles (OCT 2014) Currie Enterprise Dana 60 rear end with 4.10 gears and Detroit Tru-Trac Locker. Installed. This is a bullet proof rear axle that set me back almost $4000.
70,100 miles (JAN 2017) New 35” Milestar Patagonia M/T, 20” Mamba Matte Black Wheels with hub rings and tire pressure sensors. ($1600) Only 10,000 miles on tires.
72,000 miles (MAY 2017) Upgraded 13” Power Stop front slotted and drilled rotors, calipers and extreme pads. Power Stop rear slotted and drilled rotors, extreme pads, new parking brake shoes and ABS wheel sensors. Only 9,000 miles on brakes.
80,000 miles (MAR 2019) New Front wheel bearing & hub assembly, O2 sensors up and down stream (4 total), vapor canister vent valve, serpentine belt and PCV valve.
81,000 miles (OCT 2019) New rear brake calipers and rear axle brake lines. New radiator. Added an external trans cooler in line after the factory cooler and bypassed the prone to faliure routing thru the radiator.
Banks Ram Air Intake.
Nismo CAT back dual exhaust.
Bully Dog GT Tuner.
Bilstein 5100 shocks.
Custom built frame welded rock slides. Functional. Not wannabe step-bars.
Utili-Trac bed
Factory Bed Liner
Bed extender
PRG Products leveling kit.
PRG Products Billet Sway Bar Mounts and bushings.
Upgraded LED interior lights. LED lights wired inside topper.
PRG Alignment Cam Bolt (not installed).
PRG Products Steering Rack Bushings (not installed).
541433
541434
541435
541436
541437
541438
541443
541444
541446
The new owner got a bargain. Congrats to him.
1 - 11 of 11 Posts
