These are some of the simple things that really come in handy when tying it all together. They will really add strength where you need it without adding unneccessary weight. Many will use them with the "V" edge down when using a MIG for easy penetration, I like them flat when I TIG for a clean, tight presentation thats just as strong.
These are 1020 steel but 7/32" thick so no need for Chromoly and if its not going to be heat treated why bother anyway....They are available with a 3/4", 5/8", 9/16", or 1/2" holes and are 6 for $10....
And for after the hole has already gone oblong here are our Fixit Weld Washers. They are a tad under 7/16 thick so they will last!
Reinforcement Plates - RuffStuff Specialties
Couple guys on here could have used something like that on the lower bolt hole of their coilovers (lower control arm bolt). Somehow they expanded the size of the hole and the coilover wouldn't stay where it should.
Reactions: vilim12
Exactly what came to my mind after reading, I think reds_titan needs something like this.
