1 - 2 of 2 Posts
My 2008 Pro-4X has about 146,000 miles on it and I find myself replacing parts here and there every 1 or 2 months........Recently, it has just started not cranking about 1 out of 20 to 25 starts......
Most times, I turn the key and it'll crank right up........then it happens(or doesn't happen), I turn the key and dash lights up and radio on strong, but it won't turn over.......starter or some other ignition part?
Any advice appreciated. Part # or know how to fix especially appreciated. Thanks!
probably your starter. I experienced something similar so i replaced the starter and has been fine ever since. The only thing is you'll have to remove the intake manifold so make sure you order some new manifold gaskets beforehand. usually takes about 2 hours to do.
1 - 2 of 2 Posts
