1 - 8 of 8 Posts
My last change I switched to Mobil 1. I have not noticed anything different after switching to syntheic and I am seriously thinking about going back to Chevron supreme. I read that Chevron is really good, plus I change it out every 3000k anyway. Or should I keep using synthetic?
I run my Mobil 1 for about 7k. I was told this was fine with the Mobil1 synthetic. it comes out looking good for being in for 6-7k.
I wouldn't trust a conventional oil for that long though.
IMO, you are wasting your money on synthetics if you are changing every 3000 miles. If you are using that change interval, go back to the chevron.
agreed, not worth it.
Sorry guys, I ment I change the chevron every 3000k, sometimes less. I got 3500 on the mobil 1 right now, I was going to change it at 5000k. I was just wondering if its worth it to keep using synthetic? Thanks
I have the Royal Purple stuff and I think I'm gonna keep it in until 8K or so...the oil still looks new after 2500 miles! If you are doing 3K intervals....stick to the mineral oils cause the synthetics last a lot longer periods...and changing the synthetics at 3K's is a waist of money.
If you change the Mobil 1 before 7500 miles you are wasting your money. What do you mean you didn't notice anything different? What were you expecting? Synthetics will reduce wear, extend oil changes and prevent deposits. You would only notice the extended oil changes now. The other two you wouldn't notice for a very long time.
1 - 8 of 8 Posts
