1 - 10 of 10 Posts
Under hard acceleration I have a sound from the engine bay that almost sounds like sparking from a poor connection. I don't see any area that could be causing this. Any thoughts?
I would check Battery cables to alternator, check ground straps on engine. Have someone rev the engine and see if you can hear it. Could be a worn motor mount causing the engine to move more putting tension on Straps or Wires.
I would check for a spark plug wire arching also.
Look around and inspect closely all connection points as well for signs of arcing, a little bit of char is a good bit of evidence. As stated above, I would go through and double check all connections anyway just to be sure.
You might also pull your coil picks and check the boots to see if any are cracked and allowing arcing.
I've checked all these areas but still don't see any culprits. I've been reading way too much about the cracked manifold issue and am now freaking out it could be that lol
If what you first described as a "sparking sound," could be called a fairly loud "ticking," then there are a couple possible sources.
First, check to see if it could be injector ticking. There are some threads regarding upgraded grounds that appear to address that (although injectors may make some noise, they shouldn't be very loud). Search for the threads.
Second, the dreaded manifold cracks... the tick should be pretty noticeable at idle.
Before freaking out too much, see if you can isolate the source of the sound a bit, perhaps using a mechanics' stethoscope (or homemade facsimile of one using plastic tubing).
Good luck and Merry Christmas!
we have COP`s, coil on plugs.
This^, also does the truck miss at higher rpms?
you`d hear it more down low than at screaming speeds.
believe it or not, I had a serpentine belt make those crackling ticking noises that I could hear in the cab.
I sprayed some water on the belt and the noise temporarily went away, replaced the belt and the noise was gone.
not saying that is the noise you hear. Could the ticking be coming from the bell housing, as in cracked ring gear? they are known to make a racket under load.
what ever it is, it is loud enough for you to hear at speed in the cab.
I'm voting on cracked manifolds. No electrical arc in a 12 volt system will make that much noise.
1 - 10 of 10 Posts
