It's a package, and also part of some packages... No package, no liner :smoke:Tinman said:I was under the assumption that ALL Titan's came with a factory sprayed-in bedliner and was surprised to see some on the lot without a liner at all, or a factory insert. What's the scoop?
You know, that you should always fill gas cans on the ground! This is a law!www.durocab.com said:Bedliner is great but most importantly is the ability to tie things down anywhere in the bed not to mention no static that has been known to cause gas fires when filling up gas cans.
