I have a 2008 Titan LE with 39k miles. I have a weird sound that just started. This only happens when the truck is cold from the starting position. At 5-7 mph, just before the truck goes into the next gear, I hear a sound from the front drivers side that sounds like a loaded spring releasing. It is only when the vehicle is cold and only in the 5-7mph range. Is this normal? Any thoughts? Thanks.
i had this on my g35 and they said it had something to do with the oil consumption problems in the vq35 motors not sure if there is the same thing going on with these motors seeing im new to titans
i believe that would be the abs self test. if the sequence of events goes like this: 1: shift from 1st to 2nd, 2: abs self test (what i think your hearing), 3: doors lock directly after, 4: shift into 3rd (under light acceleration)...then thats normal. i think it actually happens closer to 10-15mph for me but never really looked that closely.
