Squeaking Noise
16231 15
I did search but couldnt find anything. :confused: I took vids and here is what it sounds like.
The 1st vid i was shaking the bed by top right corner.
The 2nd vid i was shaking the bed by the right corner of the bed.
Seems like the noise is coming from the middle right behind the cap. I was trying to shake it on the left side too but it didnt make any noise. ANy help would appreciate it, thanks guys!
1 - 16 of 16 Posts
Mine is in the passenger shackle, hit with wd-40, it shows up every 4-6 months, hit it again.
SO ANNOYING! mine does this too. I noticed it only started after I pulled the boat one time.
Get under the rear of your truck from the bumper end. Find the axle. It's the thing the wheels are attached to. There are leaf springs above the axle just to the inside of the wheels. Follow the leaf springs as the bow upwards towards the rear of the truck. The shackle attaches the leaf springs to the frame.
Reactions: Chef Titan04
Red arrow points to shackle, there is one in front of the axle and one behind it. Soak it good both sides. that should get rid of your squeek, if not. Get underneath and have someone else jump around in your truck until you track it down. My son helped me find mine.
Yeah that is annoying... yours?? Noticed the radflo's, was it them or the shackle.
That suuucks man, have you tried anything thicker than a spray? Like oil or axle grease or something?
1 - 16 of 16 Posts
