1 - 6 of 6 Posts
I’m having a frustrating starting problem the past couple weeks. So far I’ve replaced the ignition relay and strange enough had to replace my alternator this week but I think that was a separate problem. When mine happens it tends to happen after the engine gets hot. For instance the last two times it’s happened has been after driving for awhile and stopping to fill up on gas.
Today I got in, turned the key forward and absolutely nothing happened as far as it trying to turn over. Everything in truck turns on as far as radio, AC, etc but acts like I’m not even trying to start it when I turn the key forward. If I let it sit for about 5 minutes it’ll then try to turn over but it sounds weird and won’t start. If I wait another 5 minutes then it’ll start right up no problem.
I’m thinking it’s gotta be the starter but don’t want to go through all the trouble if it’s not. Btw my 2011 has 414,000 miles on it and this is still the original starter. Still had the original alternator up until this past Tuesday when I got it replaced. My shop quoted me $514 to replace the starter. Is it worth paying that or should I try tackling it myself?
The price of a starter is just a tad over $100, so you'd save $400 doing it yourself.
Here's an excellent step-by-step video to see if you want to do it first...
Before you change the starter, have you battery tested, and check your grounds and positive connections for corrosion. These trucks do strange things when the battery is dying.
Discussion Starter #4
Cheapest I can find it here in town is $200 plus $40 gasket set and that’s for one with bad reviews. I can’t afford to wait for one ordered since this is my only means of transportation.
They tested all of that when they replaced my alternator. They did replace my positive battery terminal. Even if it doesn’t fix my problem I need a new starter. It’s been slowly slowing down over the past year.
Discussion Starter #6
Replaced the starter and haven’t had an issue since.
1 - 6 of 6 Posts
