I'm having some starting problems and seen a video that mentioned replacing the starter relay on the IPMD, not the ECU relay. My problem is the dealer can't find a breakdown of the IPMD to show the individual relays. I have the older IPMD and the numbers on the installed relay show AMC33201. Is there a Nissan part number that references this? The only thing I could find is 284b7-cw29e, but this is also the ECU relay.
The relay schematic is on the inside cover of the ipdm. How would your dealer not know that.
Mine only shows the fuses and their amperages. Doesn't show the relays at all or provide any Nissan part numbers. Their manual only has the IPDM part number and doesn't break down the IPDM.
Do you think I could call Nissan directly?
Yes.
