Yesterday, every so often, the blower motor would just just stop for a few minutes and start again. After doing some research on this forum, I called my dealer and ordered a new VBC. I installed that this evening and jumped in the truck to go to dinner. All of a sudden I have ABS, SLIP, and VDC off lights on. I hit the break to stop at the next red light and the abs engaged at a super low speed. Any ideas? Thank you all so much.
Sent from my Nexus 5X using Tapatalk
So I have had those lights come before also. Last time was 2yrs ago, took to dealer and they said both front hub bearing were bad sounded about right considering the noise I was hearing when going around corners. Replaced those no more lights. New hubs have new wheel sensors. Then last week all three lights came back on. I had bought new e-brake shoes due to reading about them coming apart so why not go ahead and change them before they do. Replaced e brake shoes still had lights. I did notice rear pads were getting a little low. Checked brake fluid, it was like a hair low below max line. Topped off fluid and a day later no more lights.
more than likely a hub assembly. had this happen on my last T. pretty easy fix. you'll notice it will not go into 4x4 as long as those lights are on as well. I figured that out the hard way in the winter time.
2008 kc se 4x4
I also had a similar experience when I did my ebrake pads, think I might've gotten pb blaster or brake clean on the abs sensor. The lights came on the first time I drove the truck after I did the work and went off the same day with me doing nothing.
