Hey Gang
I did a search to figure this out...and after 10 pages..i was like...wtf... ill post it
I have gear shifter on the column and the Manual shift from 1-4 button is not working...
can SOMEONE/ANYONE...tell me where the fuse to this is located???
i don't have my personal handbook any longer...
Thanks in advance!
JB
Here you go.
http://www.titantalk.com/forums/1865048-post14.html
I checked mine and my black wire was fine so I have to wonder if there is a fuse related to this issue or not.
Also, I wonder if the F9 connector is bad, whether this would also cause these symptoms. F9 connector is a GREEN connector/harness on the underside of the transmission on the right side. I would appreciate someone chiming in with regards to whether a bad F9 connector would cause manual shifting mode to stop working.
