'08 2WD w/ 25k miles. Searched death wobble and other threads about this problem and most are '04-'06 with the smaller Frontier brakes that are prone to warping. Since I'm an '08 I have the bigger brake rotors but could it be possible the rotors have warped? I find it strange they would go so early. It only happens when you're slowly stopping from say 10-15MPH to a stop. If you press the brakes more aggressively the problem isn't as noticeable. Strange thing is I only started noticing this after I went in for an alignment after I did the mini-lift.
Help!
Thanks!
Gene
Help!
Thanks!
Gene
