All on the truck for less than 1 month.
Powerbass 6x9, Dual 4 ohm
Already mounted on the Titan bracket & with an additional 1/4" spacer so it doesn't hit the door. Wired up at 2 ohms with the specific titan plug. Plug & play!
Kicker Comp RT 8" Dual 2 ohm Subwoofer.
This will fit the stock Rockford sub box & it will fit the Fender sub bx if you trim the fins inside the box for clearance.
Kicker 3/4" Tweeters.
These will pop right in the factory Fender audio A-pillar location with the included backstrap. Crossover NOT included. Crossovers can be had on amazon for about $15. ~4500hz cutoff
Kicker KS 2.75" speakers
2 sets - I was running them in all 3 dash locations. So there is an extra speaker.
Metra rear door speaker adaptors & wiring harness.
Short "Stubby" Antenna
All in, it was about $400 new. Looking to get $250
