1 - 20 of 28 Posts
Got a 2006 LE 4X4 crew cab. Just ordered a Stillen front sway bar, what should I expect as far as handling changes??? Are the changes I've read about as incredible as they say??
I am very pleased with Stillen Front Sway Bar. Even with the Stillen Rear Sway Bar already installed, I immediately felt the improved stability after the front bar was installed. Like my screen name, it drives like a TitanZ...smiling.
Discussion Starter #4
That's what I hoped. That 4X4 is heavy on the front anyway. NOT like the old 05' 2wd....Can't wait till friday.
Super Moderator
debos titan said:
now you can take turns a ludachris speeds
Not on those SRA's he's running. :lol:
Now how about the Hellwig rear too?
I see references to the Stillen rear sway bar but when I go to stillen.com to order it never shows up. Where did you get yours from?
Call direct and talk with Kyle to uy the Rear Sway Bar. They are not making the Rear anymore, as it didn't sell well and was basically sold near cost. They still have some though. I just bought mine about 6 weeks ago. Front and Rear. I love my 2-3/4 ton Go-Kart! Amazing how flat the cornereing is, no weebles, no wobbles!
Are there fitment issues with the PRG 4 in lift?
Super Moderator
There shouldn't be any fitment issues. They sell different lengths of links, just buy the one appropriate for your lift.
And sure, why not on a lifted truck? At least moderately lifted.
There will be no fitment issues with any lift kits. It doesn't matter if you have a 2 inch leveling kit or a 15 inch bulletproof lift. The front sway bar will work perfectly fine for you. You will only need extended end links for the rear sway bar. We have those in stock as well. But, for the front bar, you will be fine with whatever end links you currently have.
I don't think the 4" spindle lift requires extended end links, I do know that the 6-8 inch lift kits all come with extended end links and they all mount up to our bar.
crownsey54 said:
would you use them on a lifted truck?
On a lifted truck you probably have more sway than on a stock suspension truck and unless you want/need articulation (rock climbing, etc), the sway bars would be a great idea.
Discussion Starter #15
Whats funny about the SRAs???? It's a 4X4 TRUCK, SRAs are an excellent balance between street and off-road. I can't help it if someone put long stretches of cement between the mudholes:rolleyes: Now, if I still had my 05' KC 2WD, different story. Oh yeah, Carbeaux, watch out for those potholes:coolsmile
Is the front sway bar pretty easy to install? Do you need any special tools?
Nothing special required. A metric socket set, metric box open wrenches, a breaker bar will take care of it. If you have a skid plate, you need to take that off. It uses the OEM bushings. If your bushings are old/worn, you might want to get a couple of new sway bar bushings from the dealer (they are cheap).
That's kind of what I was thinking.
the SRA's do not have a lot of traction. they ride nice but slip easily on take off. if you try to turn real hard on them the sidewalls will flex and you will hear them start to squeal.
So it looks like you got the front bar installed. Did you end up passing on the rear? How is the ride with front installed? I need to do something to keep my 07 CC front end from moving around.
JJ
1 - 20 of 28 Posts
