Hello To Each and All,
First I would like to thank everyone for their time,efforts,and knowledge in the discovery of our Titans. Nissan owes a debt of gratitude to the people of this forum!
Now to my observations and questions of airbox mods.
I have performed the stock airbox mod of removing the external air tube extending into the box (per Juma's post of this mod.). Instead of using a dremel tool,I found it easier to mark with a pencil the tube portion to cut to make it flush with the opening. Remove the lower airbox via two screws(1 inside the lower box and the other on the wheel well) and pull straight up to loosen the grommet hold fitting. The tube can then be separated (with effort) from the airbox and cut with a hacksaw. Don't worry about damage to the upper and lower plastic tabs holding the external tube to the airbox as with re-assembly the two parts are held together anyway.
I can't say that I have noticed a big difference(yet?) with this mod but it is a part of improvements that do add to the sum of gains. More importantly,doing this mod brings up the question of adding tubing to the end of the airhorn for a "ram air" cold air induction! The inner fender well area does allow for us to receive "cold" air but,it is loaded with many turns and flow-blocking items.
Of course,there is no free lunch so here are the problems: 1.)Where to begin the "ram" entry? 2.) Can the ECU(engine computer) handle the increased air flow? 3.) Can the stock airbox(and thus flat stock air filter)handle a ram effect?
Yes, I have thought of installing the aftermarket Volant or K&N total air systems,but neither is a "ram" system and both must still pull through the 'dirty' area of the fender well. My living in California and having visual smog inspections also plays a part in keeping a visual "stock" looking airbox. I will be installing a drop-in K&N air filter in place of the stock paper filter.
My questions also are: 1.) How do you remove the headlight assembly? 2.) How do you remove the insert in the foglight tunnel for those of us without foglights. I tried to remove both of the above and was afraid of breaking the plastic parts or worse. These two locations are possible entry points for the ram air system.
Entry points: 1.) Going behind the headlight to open at the radiator grille. This is a tight and twisty route that will call for fexilbe ducting to even have a chance to fit! This route is 'dirty' but,less cutting is necessary to connect airhorn to ram opening. Also,why do we have those plastic deflectors on the two ends of our radiator grille openings. It looks as though they direct air towards the center grille opening. I do not have the 'Tow Package' and thus maybe(?) these are only added behind the grille end openings as not that much cooling is needed?
2.) Foglight tunnel opening as the entry point for the ram opening. While this is a great opening and attachment point, cutting through the plastic shelf that is behind and below the headlight would be necessary. It also looks like this piece may be a brace of some sort? Nice smooth elbows and smooth ducts appear possible on this route instead of the 'dirty' flexible aluminum tubing necessary on route 1. above.
By the way,there is plenty of room(almost 6 inches) between the airhorn opening and the fender to easily install a deflector or better yet, a 90 degree or less elbow heading towards the front of the truck for your ram entry.
In the spirit of this board and its great and heplful people, I am trying to make this something we all could tackle and that would improve our performance also. Yes, the pros would remove fenders,panels,make specs.,and charge us big money but,it's nice to buy $20 of materials and take a Saturday afternoon and feel good that we can still do some things ourselfs. It won't be perfect,it won't give you 20+ hp,it won't make you rich,it won't settle any arguments,it won't help you lose weight, but it will be your's to share and care! Invite over some friends or better yet have your spouse or kids help and share in what's important(them and your Titan) in your life!
Let me know your thoughts and results!!!
Thanks Ladies and Gentlemen.
