Stock wheels and Lift
1056 Views 1 Reply 2 Participants Last post by  NorCal 4x4
I recently put a Pro Comp 6" lift on my 2007 Nissan Titan and I am currently running BFG 35x12.50r18 on the stock wheels. My question is I ordered 325/65R18 all terrain and didnt think about them fitting on the stock wheels or if they will rub anywhwere. could someone please tell me if they will work. Thank You
1 - 2 of 2 Posts
Are your current BFG 35x12.5x18 the MT KM?
Do you have a little extra clearance now? The new tires should be about 7/10" wider based on average spec sheet values. This is split between both side of the tire, so each side of the new ATs will stick out, (and in), about 3/8" more than the MT KM Tires.
BFG MT KM 35x12.5x18 specs.
Suggested Rim 8.5-11"
Spec. sheet measuring rim 10" = 12.5" sidewall width.
Titan 8" rim should pull it in 0.8" to about 11.7" sidewall width.
34.5"dia.
BFG AT KO 325/65/18 specs.
Suggested Rim 9-12"
Spec. sheet measuring Rim 9.5" = 13" sidewall width.
Titan 8" rim should pull it in 0.6" to about 12.4" sidewall width.
34.7" dia.​
BFG said:
1. The dimensions shown are average tire design values for tires measured on specified measuring rim widths. Some tires may vary for this value by +/- 3% of the section height (affecting overall diameter), and +3/-4% of the section width.
2. Section width varies approximately 0.2" (5mm) for every 0.5" change in rim width.
Oh, here's a link to a thread on the Kumho KL78 AT, 325/65/18 on stock rims with just leveling kits, (see posts 6 and 13). From one of the posts it sounds like their spec. sheet info. for the width matches the BFG AT.
http://www.titantalk.com/forums/titan-wheels-tires-brakes/49412-325-65-stock-18-rim.html
1 - 2 of 2 Posts
