im not sure if this is how the titans are wired, cause i havent had any issues yet ::fingers crossed:: and correct me if im wrong, but on most cars and trucks a break light is a combination of both blinkers going off at the same time and the chmsl or center break light is the only one that runs on its own switch directly connected to the break. so saying as how both a taillight and a blinker are out only on one side this strongly implies that it is not a sensor or electronic problem from before the pedal. i would check, as fanz said, below the bed and see if your exhaust burnt through it or if the connectors in the back of the light housing came loose from a large bump or hit, or perhaps the unexpected happened and all the lights went bad at the same time
iffy at best but ive seen it happen before. good luck, keep us updated on progress. also if all the wires are connect use a volt meter to test the ends where it plugs into the tail light, and either have someone hold down the break or turn the blinker on before hand!
