21 - 21 of 21 Posts
Discussion Starter #21
I didn't see any reference to how much spacer you were putting in, but if it's too tall, you may also be bottoming out your UCA at the coil bucket. Grinding might help, but you may also need a UCA that's corrected for the lift. Also, did you install cam bolts? If not, your alignment guy may hate you. Good luck.
:wink: Yeah, installed the cam bolts. Read about all the horror stories about tearing up cam bolts trying to take them out. Mine came out fine.
Just drove it to get new tires and aligned. It drove fine with no problems. Let's hope those springs settle a bit.
21 - 21 of 21 Posts
