My 2006 titan LE was stuck in park. I popped out the tab on the console and stuck a screwdriver down to release the safety mechanism so i could drive home.
On my way home i noticed my right signal light would only blink once. I believe they usually blink fast when they are ready to burn out.. My left turn signal worked fine. upon further investigation i learned my hazard lights blink only once as well.
There is a 10 amp fuse near the passenger door that kept popping whenever i would step on the brake pedal and eventually replaced it with a 15 amp fuse. It no longer pops when i step on the pedal and the shifter shifts normally. However my right signal and hazards are still messed up!
Anyone have an electrical print or advice to offer?
Check your wiring harness above the rear axle/exhaust pipe. If your exhaust has rusted out, which is common, it has a tendency to blow hot exhaust gas on the wiring harness and melt it
