1 - 12 of 12 Posts
I want to paint the removable pieces black... any suggestions? I was thinking bedliner then maybe a small clear coat over that? Just want something that will stick well with a satin finish... examples would be great!
What's up with you guys and bedliner?
That will make a really rough texture and then putting clear coat over it will make it shiny and rough. At the bare minimum, find a tupperware lid and paint on it as a sample.
If you want a satin finish, get satin black krylon for plastic and paint multiple light coats on it.
Reactions: bills1974
I sanded them down, used a couple coats of Rustoleum for plastic then a couple coats of clear. It's held up great.
Did you use the Rustoleum Clear Coat for plastic? I know that is a partial dumb question but there are a lot of different clear coat sprays out there...
I sprayed the Krylon on there with about 4 light coats and it didn't hold for crap... I'm thinking do the Rustoleum Plastic primer then spray it with Rustoleum Spray for plastic... Maybe some clear coats if I don't like the finish...
Reactions: gweasel77
Also... bedliner is awesome :) Maybe not in this application but it is awesome nonetheless :D
Yes, I did...
Discussion Starter · #10 ·
If you paint clear over satin, doesn't it create gloss black?
Yes, the bedliner stuff is awesome. Will probably use it for my bumpers.
It's a little glossed, but I love the way it looks
1 - 12 of 12 Posts
