I have the LE CC and my sunroof leaks!!! When I shut the sunroof I can hear wind coming through it like it isnt all the way down and I can see the gap in the sunrrof!
Super Moderator
Where is the gap?
Don't want to overlook the obvious but have you checked to make sure that that not only the open-close switch has been closed but the up-down switch has been put in the down position as well?
I'd forgotten the up-down switch once and it rained and I got some moisture inside, not much but some. :upsidedow
Yes, I tried everything and had someone else check it too. The Gap is where the roof gets cracked.
it may need to be realigned i would take it to the dealer and have them check it
