Here is a closer pic with the rustoleum bedliner. I took the grill off and sanded the chrome down on everything except the steps (they weren't chrome), used 80 grit and a palm sander. Tape the bumpers off and use newspapers to cover anything you don't want spray on. Clean everything off with paint thinner, spray the primer and let sit until it gets tacky then start spraying bedliner on. When you spray use light coats and spray from about 12 inches away otherwise you will put it on too thick and it will start to run, I used about 4 or 5 coats.
