Swaping an 08 axle to an 06 titan
1638 Views 14 Replies 7 Participants Last post by  gweasel77
I am driving a couple hours to a get this axle and I am going to swap axles in a parking lot. I'm trying to find out the differences in the two so I can get them both going in a timely manner. From what I found out so far the only problem I would have would be the brake lines and I should be able to just swap them between axles but the brackets are different. Any one done this (I'm sure a lot of people have)? Is there anything I am missing? Will my calipers bolt on to his axle?
1 - 15 of 15 Posts
Good question about the brake lines! All, if any part will be available from the local Nissan parts dept. or online. Your rear calipers should bolt right up.
Finally people are starting to get the hint that you can swap axles & have TruTrac!
Keep us posted! :)
Maybe I am reading it wrong but it looks to me like they are the same... It lists a part number of 37320 as the rear drive shaft on the top and bottom. The drawing numbers are different and only thing I can see that is different is that the newer drawing is lacking part numbers for parts that are on the drawing (shows parts with no numbers for them). Am I missing something terribly obvious??
im wanting to do the same so keep us posted on the final outcome it would be appreciate!
They might bolt up, I dunno, but they have different part listings for the rear drive shaft, I dunno what is different.
Home » Titan Parts (A60) 2004-2011 » Genuine Nissan Parts » Power Train » 370 Propeller Shaft » [37320] \(A60
370 Propeller Shaft
These products matched your selected vehicle...
Products
Displaying 1 to 3 (of 3 products) Result Pages: 1
[37320] SHAFT ASSEMBLY-REAR PROPELLER
Titan (A60) 37300-A60003
2004-2006 4WD
More Info Price: $420.35
Titan (A60) 37300-A60005
2007 4WD
2008-2011 4WD/SB
More Info Price: $469.17
Titan (A60) 37300-A60006
2008-2011 4WD/LB
More Info Price: $859.55
Wednesday 22 June, 2011
Discussion Starter · #8 ·
I see.... Sorry I was taking the 37320 as the part number... I'm dumb. From a quick search it looks like the current part number for the drive shafts made for Titans from 08/2006 are the same all the way through 03/2010. There is a different shaft made for the 10/2004 - 08/2008. Four wheel models that is. I don't have my Titan here to verify the year (it's at Nissan) but it should be made in 05 seeing as how it is a 06. I guess I will have to learn the hard way and just try it... I can also get his drive shaft if they are different, and hopefully it will mate to the tranny... Thanks for all the advice.
Sweeeeeet....moderators can edit other people's comments?? (comment #4) thats b!tchin
how else would they monitor :p but back on subject, all this is awesome information guys helps out us newbies who need tru trac!
I am a 2WD 06 Titan. Nissan swapped my 06 Axle out and installed an 08 Axle without any other parts that I am aware of. The only extra stuff, was to transfer my Stillen Sway Bar Mounts. They transferred the Brake Calipers iirc; I think I ended up with new Rotors, but am not sure on that. It has been trouble free.
Reactions: gweasel77
I bent an axle shaft way back & i replaced it with one off an '06. I think they changed axles in '08? The newer axles has more splines than the older ones. Not sure about 4x4...but i guess that won't matter f you swap the whole unit.
1 - 15 of 15 Posts
