1 - 2 of 2 Posts
Urethane or Rubber?
Replace the links too?
Suspension is getting creaky and rattily.
Urethane would last longer but would it be much harsher than the rubber ones.
Would replacing the links be very hard and are they under a lot of tension I need to be aware of?
These parts are not very expensive so looking at these.
2004 Titan LE 4WD
Links are really easy to swap out, just make sure your tires are straight and level when you tighten them back up.
when one of mine snapped, I replaced both with MOOG links.
Thought about doing the bushings, I got some rubber ones (arno bently or whatever) just havent had the will to get under there again and see how many bolts snap trying to get the sway bar bolts open.
1 - 2 of 2 Posts
