1 - 6 of 6 Posts
I just installed mid travel kit from DK , upper and lower control arms , and the swaybar has been removed. Does anyone know if I need to install the swaybar to do alignment? I'm confused on that , some people say you need it and others say not because is after market and they come with misalignment spacers. Any body has an idea?
Nope. Haven't had my sway bar on for years, and I get an alignment every 6 months. All they do is clamp the wheels and adjust it.
If your going to run a sway bar get it aligned with it on. The truck will sit slightly lower with it on ad the geometry will be slightly different with it off. I don't run a sway bar either. some people like them and some don't. On trucks I prefer them off as the ride is way softer when hitting bumps and so on.
Discussion Starter #4
Thanks guys for the advice, I'm going to stay without the swaybar. I been driving my truck already for about two weeks with this new parts and the only thing I noticed is a little bit of body roll when I hit bumps on the freeway doing 85+ , I believe has a lot to do with the lift difference between front and rear but I will fix that soon adhering a few more leaf springs. This is the way it looks right now
Spindles and dk mid travel? with some deaver springs that thing is gonna ride like a cloud. nice work man.
1 - 6 of 6 Posts
