NOT your current receiver! Each company uses an entirely different way of encoding their stream and current receivers for one won't work with the other. Future receivers, assuming the merger is approved, will probably be able to receive both services.twistedfreedom said:If I remember correctly XM and Sirius are merging, allowing all channels from both companys to be played on the same reciever.
rye said:I would like to switch to sirius but need some help, where is and how do you remove the xm tuner. Anyone that can help your info will be much appreciated
