What is this? How do you do this? What kind of performance gain is acheived?
There are two plastic lines running through the throttle body, keeping the TB hot as hell. What you do is, you remove the two lines and plug the holes with bubble gum. Then, you rev your engine really high and do a neutral drop. Accelerate to 114 mph, this should get the coolant temperature nice and high so the gum will pop out. Then, you coolant will jet out all over the place, smelling great and giving nice birdies and kitties somthing to drink.TitanRider said:What is this? How do you do this? What kind of performance gain is acheived?
Yeah, I think he likes to use his Titan as a guinea pig!!:lol:ablexus said:You could do the entire mod without anything other than that picture.
Thanks to JetTech for constructing perfectly labeled pictures.
Andrew
I'm sure the dealer would think so. Anyway it's not hard or take long to revert back to normal before you take it in. If you decide to do it let us know how it turn out.:cheers:TitanRider said:Would this void the warranty? Thanks for all the info and I did try the search and nothing remotely close popped up so I posted so I could get some real answers.
baseballfanz said:The theory behind that is if you remove the hot coolant circulating around the throttle body, thus giving you colder denser air going into teh intake. You basically bypass the throttle body and rerouting the coolant. Does it work I don't know as I have not tried it yet.:cheers:
I have not done this but on average the Titan coolant temp. is 190F, the avg. air intake is 100 - 120F depending on the intake that's use. So in theory taking the 190F coolant temp away from the TB should cool it down a bit.04RamHemi said:but why would you intentionally increase the temp of your incoming air? There has to be a reason behind it.
I think the extra 10 on the QX come from the 2 degree advance from the factory, why else would they required 93 octane? Not sure just a guess.bbomar said:Then I have to ask the question. Are the Armada and QX56 setup the same way?? Is this to somewhat curve HP on the Titan? I really don't think it would curve it, but then again....
will not "bounce off speed limiter" just smoothly stop pulling.... and the block would fuse to a giant hunk of aluminium....not steelablexus said:There are two plastic lines running through the throttle body, keeping the TB hot as hell. What you do is, you remove the two lines and plug the holes with bubble gum. Then, you rev your engine really high and do a neutral drop. Accelerate to 114 mph, this should get the coolant temperature nice and high so the gum will pop out. Then, you coolant will jet out all over the place, smelling great and giving nice birdies and kitties somthing to drink.
After a while, your temperature gauge will go up. Ignore this. Continue driving, bouncing the truck against the speed limiter, until your block fuses into a giant hunk of steel.
And whammo! Enjoy your brand new boat anchor! Guaranteed to sink to the bottom of the ocean faster than your old Titan.
Andrew
PS do a search. This is one of the few sites with good search engines. I think I spent a week on this forum reading before I posted anything.
RockyMtMan did this but he put a valve on it to close up the flow, when he need to in the winter time he just turn the valve to let it flow again.TitanRider said:I will do it when I have the time. Why don't you guys try it out? I think it won't hurt anything as long as the outside air doesn't go below freezing.
No, I was not asking the Titan owners, I was questioning why Nissan would have hot coolant around the Throttle body. Talk about killing performance. There are not any coolant lines that I can see by my TB on the Ram, but now I have to go look!baseballfanz said:I have not done this but on average the Titan coolant temp. is 190F, the avg. air intake is 100 - 120F depending on the intake that's use. So in theory taking the 190F coolant temp away from the TB should cool it down a bit.
My intake temp is usually at 120F, the other day when my truck kinda overheat the intake temp went to 159F so coolant temp would affect intake temp.
Sorry... used to vehicles with iron blocks, and manuals which "bounce" when the fuel cutoff occurs. Thanks for the clarification.StuntDriver06 said:will not "bounce off speed limiter" just smoothly stop pulling.... and the block would fuse to a giant hunk of aluminium....not steel
My bad, just re-read your post slowly and carefully and see you are asking why Nissan did this.04RamHemi said:No, I was not asking the Titan owners, I was questioning why Nissan would have hot coolant around the Throttle body. Talk about killing performance. There are not any coolant lines that I can see by my TB on the Ram, but now I have to go look!
