1 - 3 of 3 Posts
I have the all too common ABS and slip lights on in the dash and need to figure out how to either test the sensors or pull the abs codes. I've tried two separate code readers with no luck because the abs codes are apparently stored in the BCM. I tried pulling the codes by using the check engine light method and still no dice. I've also searched for info on how to test the sensors with a multi meter but haven't really found any solid info. The only thing I can find says to check the ohm reading but didn't say what a the ohm readings would be on a good or bad sensor.
I was also wondering if the torque app can pull bcm codes? I'm pretty sure I read somewhere that you can with uprev, bud don't know anyone close who has it. The last resort is going to nissan and paying them to pull the code, but I'm too stubborn to do it and don't want to part with the cash.
Any suggestions are greatly appreciated.
You're right, UpRev can read ABS codes. Some shops have scanners than can read them...
1 - 3 of 3 Posts
