1 - 3 of 3 Posts
Difference between left/right fog lights...
I'm new here, so I hope you all don't mind me asking a few questions:
If I were to find two used OEM right hand side (i.e. passenger-side) fog lights for real cheap, would I be able to successfully mount and use one on the driver's side and one on the passenger's side?
If it can be done, would it be noticeable?
What is the actual difference between the two assemblies?
Will there be a problem with the plug-and-play wiring if I attempt this?
Please let me know your thoughts so I can either go ahead and buy these two lights (and, of course, a fog light enabled stock) or rule this out as an option.
Thanks, all!
Adam
Each is beveled a certain direction to fit the hole, and has a bolt and a pivot point to fit right, so it is secure and will adjust aim. It may be done, if you fabricate by removing the back of the bumper and flip it upside down. i don't think it is worth hacking the bumper up, and reglueing to save the few bucks on it.
Thanks, man. That's exactly what I wanted to know.
I know my 2009 stalk is different from from previous year models, so I need to be sure I get the right stalk. Do you (or anyone else) have any suggestions on where to get a set of factory fog lights? I've found a few places online, but it's not very clear what version of the stalk comes with the kit(a).
1 - 3 of 3 Posts
